Compaq Presario CQ60 Motherboard Replacement
Lift the keyboard in the middle with a spudger
Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
Do not remove the keyboard fully, it is attached via a ribbon cable
Lift keyboard slightly
Push each side of ribbon cable connector
Fully remove keyboard
Remove 2x Phillips M2.5x8mm screws from under the display
Remove 4x Phillips M2x2.8mm screws from the battery compartment
Turn over the laptop
Use a spudger to lift the ribbon cable hinged clip
Pull the ribbon cable out of the connector
Remove 4x #1 Phillips M2.5x8mm screws from the bottom case
Remove 2x #0 Phillips M2x4mm screws from hard drive bay
Using a spudger lift the mouse ribbon cabe latch
Do not remove yet
다른 한 분이 해당 안내서를 완성하였습니다.
