주요 콘텐츠로 건너뛰기
Compaq Presario CQ60-211DX Display Assembly Replacement
Garrett Carter
Garrett Carter4 다른 기여자
최종 수정일 January 16, 2025
5 분
조정
더 나은 이미지가 필요함
This guide will show how to remove and replace the display assembly on a Compaq Presario CQ60-211DX laptop.
필요한 것
도구
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Compaq Presario CQ60-211DX Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Compaq Presario CQ60-211DX Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Carter
회원 가입일: 09/21/18
492 평판
안내서 4개를 작성함
댓글 2개
My laptop model Compaq predario cq61 h
Rashid 007 - 답글
Computer on but display light of computer is running
Rashid 007 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 6
전체 시간: 1,275
