주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
필요한 것
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
    댓글 쓰기
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 2 단계, 이미지 2개 중 1개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
    댓글 쓰기
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 3 단계, 이미지 3개 중 1개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 3 단계, 이미지 3개 중 2개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 3 단계, 이미지 3개 중 3개
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
    댓글 쓰기
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: 4 단계, 이미지 2개 중 1개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: 4 단계, 이미지 2개 중 2개
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
    댓글 쓰기
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 5 단계, 이미지 3개 중 1개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 5 단계, 이미지 3개 중 2개 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 5 단계, 이미지 3개 중 3개
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
    댓글 쓰기
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: 6 단계, 이미지 1개 중 1개
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
    댓글 쓰기
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: 7 단계, 이미지 1개 중 1개
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Timothy Lo
회원 가입일: 04/22/14
1,214 평판
안내서 7개를 작성함
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G58
4 회원들
안내서 14개를 작성함
2가이드 댓글
so where do you buy parts???
akatser1 - 답글 공유
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 50
전체 시간: 5,274
