주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creating a Buttonhole Using a Sewing Machine
필요한 것
    1. Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: 1 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: 1 단계, 이미지 2개 중 2개
      • Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
      • Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
      댓글 쓰기
    2. Creating a Buttonhole Using a Sewing Machine: 2 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 2 단계, 이미지 2개 중 2개
      • Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
      • You can measure your button if you aren't sure.
      • Align the sewing machine at the upper left corner of the buttonhole.
      댓글 쓰기
    3. Creating a Buttonhole Using a Sewing Machine: 3 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 3 단계, 이미지 2개 중 2개
      댓글 쓰기
    4. Creating a Buttonhole Using a Sewing Machine: 4 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 4 단계, 이미지 2개 중 2개
      • Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
      댓글 쓰기
    5. Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 1개 Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 2개 Creating a Buttonhole Using a Sewing Machine: 5 단계, 이미지 3개 중 3개
      • Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
      • Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that.
      • Start sewing. Sew to your second line.
      댓글 쓰기
    6. Creating a Buttonhole Using a Sewing Machine: 6 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 6 단계, 이미지 2개 중 2개
      • Set your button hole dial to two.
      • Sew the bar tack at the bottom of the buttonhole.
      • Setting the button hole dial to two tells your sewing machine what to do, all you need to do is sew a few stitches to create the bar tack.
      댓글 쓰기
    7. Creating a Buttonhole Using a Sewing Machine: 7 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 7 단계, 이미지 2개 중 2개
      • Set your buttonhole dial to three.
      • Sew up the second side of your buttonhole, stopping at your top mark.
      댓글 쓰기
    8. Creating a Buttonhole Using a Sewing Machine: 8 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 8 단계, 이미지 2개 중 2개
      • Set your buttonhole dial to four.
      • Sew the top bar tack at the top of the buttonhole.
      댓글 쓰기
    9. Creating a Buttonhole Using a Sewing Machine: 9 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 9 단계, 이미지 2개 중 2개
      • Set your buttonhole dial to five.
      • This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
      댓글 쓰기
    10. Creating a Buttonhole Using a Sewing Machine: 10 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 10 단계, 이미지 2개 중 2개
      • Clip the threads, freeing the fabric from the machine.
      • Clip any extra loose threads.
      댓글 쓰기
    11. Creating a Buttonhole Using a Sewing Machine: 11 단계, 이미지 2개 중 1개 Creating a Buttonhole Using a Sewing Machine: 11 단계, 이미지 2개 중 2개
      • Use a hobby knife to cut open the buttonhole.
      • Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
91,032 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 70,339개를 작성함
2가이드 댓글
I got up to position (!) 2 ok, then when I tried to go back up on position 3 it didn't work and just chewed up my fabric. Is it supposed to go backwards, or are you supposed to turn the fabric around? Did I do something wrong?
Holly - 답글 공유
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
Roszarie - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 92
전체 시간: 29,930
