주요 콘텐츠로 건너뛰기
Cricut Maker Roller Bar Replacement
Devyn White
Devyn White3 다른 기여자
최종 수정일 March 25, 2024
1 - 2 시간
조정
더 나은 이미지가 필요함
더 많은 이미지가 필요함
The roller bar mechanism of the Cricut Maker is the piece that allows the machine to create these designs and patterns. It rotates to keep the blades and engraving tips in line and precise.
If you find that your roller bar is not working, or it is damaged, this replacement guide is for you!
Before you begin the repair, be sure to turn the device off and unplug it from the outlet.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 3개
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Roller Bar Replacement: 2 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Roller Bar Replacement: 3 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 3 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Roller Bar Replacement: 4 단계, 이미지 1개 중 1개
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Roller Bar Replacement, Front Door Replacement: 5 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement, Front Door Replacement: 5 단계, 이미지 2개 중 2개
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Roller Bar Replacement: 6 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 6 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Roller Bar Replacement: 7 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 7 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 7 단계, 이미지 3개 중 3개
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Roller Bar Replacement: 8 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 8 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Roller Bar Replacement: 9 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 9 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Roller Bar Replacement: 10 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 10 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 10 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Roller Bar Replacement: 11 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 11 단계, 이미지 2개 중 2개
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Roller Bar Replacement: 12 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 12 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Roller Bar Replacement: 13 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 13 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 13 단계, 이미지 3개 중 3개
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Roller Bar Replacement: 14 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 14 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 14 단계, 이미지 3개 중 3개
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Roller Bar Replacement, Motor: 15 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement, Motor: 15 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
  16. Cricut Maker Roller Bar Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the motor by pulling it from the device.
  17. Cricut Maker Roller Bar Replacement: 17 단계, 이미지 1개 중 1개
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
  18. Cricut Maker Roller Bar Replacement: 18 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
  19. Cricut Maker Roller Bar Replacement: 19 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 19 단계, 이미지 2개 중 2개
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
  20. Cricut Maker Roller Bar Replacement: 20 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 20 단계, 이미지 2개 중 2개
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
  21. Cricut Maker Roller Bar Replacement, Belt: 21 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement, Belt: 21 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement, Belt: 21 단계, 이미지 3개 중 3개
    • Remove the two 10 mm screws using a Phillips #2 screwdriver.
  22. Cricut Maker Roller Bar Replacement: 22 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 22 단계, 이미지 2개 중 2개
    • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
  23. Cricut Maker Roller Bar Replacement: 23 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 23 단계, 이미지 2개 중 2개
    • Pull the bar containing the axel and metal attachment out to remove them.
    • This should free the remaining side of the belt.
  24. Cricut Maker Roller Bar Replacement: 24 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 24 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
  25. Cricut Maker Roller Bar Replacement: 25 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 25 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 25 단계, 이미지 3개 중 3개
    • Remove the electrical tape from the connecting cable on the backside of the main motor.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Pull the cable out.
  26. Cricut Maker Roller Bar Replacement: 26 단계, 이미지 3개 중 1개 Cricut Maker Roller Bar Replacement: 26 단계, 이미지 3개 중 2개 Cricut Maker Roller Bar Replacement: 26 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
    • Removing these two screws will cause the belt holder to detach.
    • Slip it through the hole in the main motor frame.
  27. Cricut Maker Roller Bar Replacement: 27 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement: 27 단계, 이미지 2개 중 2개
    • Remove the washer (e-clip) securing the bar to the belt holder.
    • We found it is easiest to remove by hand.
    • To remove it, simply twist and pull upwards to free it.
    • Remove the bar from the belt holder and then remove the belt holder.
    • Slip the belt out of the machine.
  28. Cricut Maker Roller Bar Replacement, Roller Bar Replacement: 28 단계, 이미지 2개 중 1개 Cricut Maker Roller Bar Replacement, Roller Bar Replacement: 28 단계, 이미지 2개 중 2개
    • Pull the bar to the right of the machine, to free it from its placement.
  29. Cricut Maker Roller Bar Replacement: 29 단계, 이미지 1개 중 1개
    • Slide the roller bar out to remove it from the machine.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Devyn White
회원 가입일: 09/20/22
1,131 평판
안내서 5개를 작성함
Austin Community College, Team 9-1, Watkins Fall 2022 Austin Community College, Team 9-1, Watkins Fall 2022 회원
AUSTINCC-WATKINS-F22S9G1
3 회원들
안내서 23개를 작성함
댓글 4개
I think there's a step missing between step 4 and 5. Took the lid off in 4 and in 5 we can already see the motor...
Jamie French - 답글
For Step #4, for some models, there's 7 silver screws you'll need to remove. You'll need a #1 driver to take them out from the ceiling of the cutting area. That allowed me to take the lid off.
A Regis - 답글
Do you have aline the gears when you put it back together that are on the left side for the small roller ?
Tim Norvill - 답글
Someone can tell me where we can get this gear?
Rachel Cadot - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 61
지난 30일: 263
전체 시간: 18,676
