주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Crosley CR42 Band Replacement
필요한 것
    1. Crosley CR42  Band Replacement, Band: 1 단계, 이미지 1개 중 1개
      • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
      • If you believe the band may be broken or out of place, start by unplugging the record player.
      댓글 쓰기
    2. Crosley CR42  Band Replacement: 2 단계, 이미지 2개 중 1개 Crosley CR42  Band Replacement: 2 단계, 이미지 2개 중 2개
      • Make sure the needle is in its resting position off to the side.
      • Gently remove the turntable from the device by lifting it directly upward.
      댓글 쓰기
    3. Crosley CR42  Band Replacement: 3 단계, 이미지 1개 중 1개
      • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
      • Inspect your band for any tears, rips, or obvious signs of stretching.
      댓글 쓰기
    4. Crosley CR42  Band Replacement: 4 단계, 이미지 1개 중 1개
      • Flip the turntable over.
      • Locate the notch on the back side of the turntable.
      • The notch will be on the outside edge of the turntable.
      댓글 쓰기
    5. Crosley CR42  Band Replacement: 5 단계, 이미지 2개 중 1개 Crosley CR42  Band Replacement: 5 단계, 이미지 2개 중 2개
      • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
      • Loop the band around the notch, the band should be taut.
      댓글 쓰기
    6. Crosley CR42  Band Replacement: 6 단계, 이미지 2개 중 1개 Crosley CR42  Band Replacement: 6 단계, 이미지 2개 중 2개
      • Place the turntable back onto the device.
      • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
      댓글 쓰기
    7. Crosley CR42  Band Replacement: 7 단계, 이미지 1개 중 1개
      • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
      • Job well done!
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Roberto Rosila
회원 가입일: 01/26/14
328 평판
안내서 3개를 작성함
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 회원
CPSU-MANESS-W14S1G38
4 회원들
안내서 30개를 작성함
1가이드 댓글
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 62
전체 시간: 5,864
