주요 콘텐츠로 건너뛰기
CyberpowerPC Fangbook HX6 Screen Replacement
Eric Box
Eric Box2 다른 기여자
최종 수정일 July 15, 2022
9 - 10 분
조정
This guide will show you how to replace the screen in a CyberpowerPC Fangbook HX6 with minimal difficulty.
필요한 것
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 3개 중 1개 CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 3개 중 2개 CyberpowerPC Fangbook HX6 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: 3 단계, 이미지 2개 중 1개 CyberpowerPC Fangbook HX6 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: 4 단계, 이미지 2개 중 1개 CyberpowerPC Fangbook HX6 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eric Box
회원 가입일: 09/12/18
183 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 34
전체 시간: 963
