주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Phantom 3 Advanced Flight Controller Replacement
필요한 것
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Battery: 1 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
      • Remember to disarm and power down your quadcopter before beginning any disassembly.
      댓글 쓰기
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 2 단계, 이미지 2개 중 2개
      • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
      • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
      댓글 쓰기
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Cover: 3 단계, 이미지 1개 중 1개
      • Turn the Phantom 3 Advanced upside down.
      댓글 쓰기
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
      • There is one screw per arm, located at the tip of the arm.
      댓글 쓰기
    3. DJI Phantom 3 Advanced Flight Controller Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
      • There are two 5mm screws on each arm.
      댓글 쓰기
    4. DJI Phantom 3 Advanced Flight Controller Replacement: 6 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
      • There is one screw on each arm located near the landing gear.
      댓글 쓰기
    5. DJI Phantom 3 Advanced Flight Controller Replacement: 7 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 7 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced Flight Controller Replacement: 7 단계, 이미지 3개 중 3개
      • Carefully flip the phantom back over with the motors facing up.
      • Peel back the silver stickers from the seam in the cover.
      • Using a plastic spudger, slowly separate the two halves of the plastic shell.
      • This step requires some force, and the plastic will click loudly as the shell separates.
      • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
      댓글 쓰기
    6. DJI Phantom 3 Advanced Flight Controller Replacement: 8 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 8 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced Flight Controller Replacement: 8 단계, 이미지 3개 중 3개
      • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
      • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
      • Press the tab on the side of the connector and pull up on the cable.
      • Continue to remove the shell the rest of the way.
      댓글 쓰기
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Flight Controller: 9 단계, 이미지 1개 중 1개
      • Locate the five ribbon cables that need to be disconnected from the control board.
      • Locate the red and black battery wires.
      • Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
      댓글 쓰기
    2. DJI Phantom 3 Advanced Flight Controller Replacement: 10 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 10 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced Flight Controller Replacement: 10 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
      • Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
      • Desolder the battery wires.
      댓글 쓰기
    3. DJI Phantom 3 Advanced Flight Controller Replacement: 11 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the cable next to where the battery wires were connected. Pinch and hold the top of the connector, then pull it out.
      댓글 쓰기
    4. DJI Phantom 3 Advanced Flight Controller Replacement: 12 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 12 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced Flight Controller Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the black ribbon cable and the 3-wire cable next to it. Press the small tab on the ribbon cable connector and pull it out.
      댓글 쓰기
    5. DJI Phantom 3 Advanced Flight Controller Replacement: 13 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 13 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced Flight Controller Replacement: 13 단계, 이미지 3개 중 3개
      • Locate the ribbon cable that is next to the word "Front" on the flight controller.
      • Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
      • Remove the black band from the ribbon cable.
      • Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
      댓글 쓰기
    6. DJI Phantom 3 Advanced Flight Controller Replacement: 14 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced Flight Controller Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the four 6.5mm long 2mm screws with a philips head 00 screwdriver.
      • Remove the flight controller now by slowly pulling if off of the frame.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robert Comstock
회원 가입일: 10/06/16
436 평판
안내서 2개를 작성함
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G2
3 회원들
안내서 12개를 작성함
2가이드 댓글
Very clear and helpful. Thank You.
Herb - 답글 공유
Excellent with great visuals. Can really see what to do
Leo Miller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 53
전체 시간: 8,146
