주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Phantom 3 Advanced LED Replacement
필요한 것
    1. DJI Phantom 3 Advanced LED Replacement, Battery: 1 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
      • Remember to disarm and power down your quadcopter before beginning any disassembly.
      댓글 쓰기
    2. DJI Phantom 3 Advanced LED Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement: 2 단계, 이미지 2개 중 2개
      • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
      • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
      댓글 쓰기
    1. DJI Phantom 3 Advanced LED Replacement, Cover: 3 단계, 이미지 1개 중 1개
      • Turn the Phantom 3 Advanced upside down.
      댓글 쓰기
    2. DJI Phantom 3 Advanced LED Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
      • There is one screw per arm, located at the tip of the arm.
      댓글 쓰기
    3. DJI Phantom 3 Advanced LED Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
      • There are two 5mm screws on each arm.
      댓글 쓰기
    4. DJI Phantom 3 Advanced LED Replacement: 6 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
      • There is one screw on each arm located near the landing gear.
      댓글 쓰기
    5. DJI Phantom 3 Advanced LED Replacement: 7 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced LED Replacement: 7 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced LED Replacement: 7 단계, 이미지 3개 중 3개
      • Carefully flip the phantom back over with the motors facing up.
      • Peel back the silver stickers from the seam in the cover.
      • Using a plastic spudger, slowly separate the two halves of the plastic shell.
      • This step requires some force, and the plastic will click loudly as the shell separates.
      • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
      댓글 쓰기
    6. DJI Phantom 3 Advanced LED Replacement: 8 단계, 이미지 3개 중 1개 DJI Phantom 3 Advanced LED Replacement: 8 단계, 이미지 3개 중 2개 DJI Phantom 3 Advanced LED Replacement: 8 단계, 이미지 3개 중 3개
      • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
      • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
      • Press the tab on the side of the connector and pull up on the cable.
      • Continue to remove the shell the rest of the way.
      댓글 쓰기
    1. DJI Phantom 3 Advanced LED Replacement, LED: 9 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement, LED: 9 단계, 이미지 2개 중 2개
      • Follow the red,yellow and black wires from the LED to where they connect on the control board.
      • Scrape off the glue with a plastic opening tool. Use a metal opening tool if needed.
      • The LED wires are smaller than the motor wires.
      댓글 쓰기
    2. DJI Phantom 3 Advanced LED Replacement: 10 단계, 이미지 1개 중 1개
      • Desolder the red, yellow and black wires that connect the LED to the control board. Check out the link below for more information on desoldering. Desoldering Information
      댓글 쓰기
    3. DJI Phantom 3 Advanced LED Replacement: 11 단계, 이미지 2개 중 1개 DJI Phantom 3 Advanced LED Replacement: 11 단계, 이미지 2개 중 2개
      • Use a plastic opening tool and wedge it under the LED.
      • Press down on the plastic opening tool and remove the LED.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tate Morell
회원 가입일: 10/06/16
812 평판
안내서 2개를 작성함
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 29
전체 시간: 3,113
