주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DR.J Professional HI-04 Lamp Replacement
필요한 것
    1. DR.J Professional HI-04 Lamp Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 DR.J Professional HI-04 Lamp Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 DR.J Professional HI-04 Lamp Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Flip the projector so that the bottom is facing up.
      • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
      • The screws are set deep in the holes. Be careful not to drop the screws.
      • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
      댓글 쓰기
    2. DR.J Professional HI-04 Lamp Replacement: 2 단계, 이미지 3개 중 1개 DR.J Professional HI-04 Lamp Replacement: 2 단계, 이미지 3개 중 2개 DR.J Professional HI-04 Lamp Replacement: 2 단계, 이미지 3개 중 3개
      • Flip the projector so it is upright.
      • Remove the top case of the projector.
      • The top case should come off fairly easily but be gentle while removing it.
      • Don't yank the top case off as there are cables attached to the motherboard and the top case.
      댓글 쓰기
    3. DR.J Professional HI-04 Lamp Replacement: 3 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the three pieces of tape securing cables.
      • Keep the tape for reassembly.
      댓글 쓰기
    4. DR.J Professional HI-04 Lamp Replacement: 4 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
      • Be sure to not drop the screws in the device as they can be difficult to recover.
      댓글 쓰기
    5. DR.J Professional HI-04 Lamp Replacement: 5 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 5 단계, 이미지 2개 중 2개
      • Squeeze the tab against the connector, and pull the connector straight out from the socket.
      • The cable will come out easily so do not pull too hard.
      댓글 쓰기
    6. DR.J Professional HI-04 Lamp Replacement: 6 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 6 단계, 이미지 2개 중 2개
      • Lift the motherboard from the device.
      • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
      • Pull the cable from the connector.
      댓글 쓰기
    7. DR.J Professional HI-04 Lamp Replacement: 7 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 7 단계, 이미지 2개 중 2개
      • Set down the motherboard safely.
      댓글 쓰기
    1. DR.J Professional HI-04 Lamp Replacement, Lamp: 8 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement, Lamp: 8 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
      • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
      댓글 쓰기
    2. DR.J Professional HI-04 Lamp Replacement: 9 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 9 단계, 이미지 2개 중 2개
      • Gently remove the black cover.
      댓글 쓰기
    3. DR.J Professional HI-04 Lamp Replacement: 10 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the single piece of black tape.
      • Save the tape for reassembly.
      댓글 쓰기
    4. DR.J Professional HI-04 Lamp Replacement: 11 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 11 단계, 이미지 2개 중 2개
      • Use a Phillips #0 screwdriver to remove five 10.0 mm screws.
      댓글 쓰기
    5. DR.J Professional HI-04 Lamp Replacement: 12 단계, 이미지 3개 중 1개 DR.J Professional HI-04 Lamp Replacement: 12 단계, 이미지 3개 중 2개 DR.J Professional HI-04 Lamp Replacement: 12 단계, 이미지 3개 중 3개
      댓글 쓰기
    6. DR.J Professional HI-04 Lamp Replacement: 13 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the glass object with the orange ribbon cable connector.
      • Be careful removing object as it is fragile and can easily break.
      댓글 쓰기
    7. DR.J Professional HI-04 Lamp Replacement: 14 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 14 단계, 이미지 2개 중 2개
      • Use a Phillips #0 to remove four 10.0 mm screws from the lamp.
      댓글 쓰기
    8. DR.J Professional HI-04 Lamp Replacement: 15 단계, 이미지 2개 중 1개 DR.J Professional HI-04 Lamp Replacement: 15 단계, 이미지 2개 중 2개
      • Gently slide the lamp out from the projector case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Baron Dutra
회원 가입일: 11/01/23
825 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-5, Petersen Fall 2023 UMass Dartmouth, Team 1-5, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G5
4 회원들
안내서 15개를 작성함
3가이드 댓글
Hi Do you know what type of lamp can ne used for replacement please
Chilijon - 답글 공유
Where can I purchase this lamp to replace in the unit or what is the model number of the lamp so I can search it out?
Dave Haddad - 답글 공유
MTDM3025-03 is lamp part number
KCrane - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 46
전체 시간: 2,000
