주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DROCON Ninja Camera Replacement
필요한 것
    1. DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Make sure the drone is powered off before beginning the battery replacement.
      • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
      • Firmly grasp the battery tab between your thumb and index finger.
      • Pull the battery away from the drone's body
      댓글 쓰기
    1. DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 3개
      • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
      댓글 쓰기
    2. DROCON Ninja Camera Replacement: 3 단계, 이미지 2개 중 1개 DROCON Ninja Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Gently pull white casing away from the black bottom casing
      댓글 쓰기
    3. DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
      • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
      댓글 쓰기
    1. DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
      • Use your fingers to gently pull the white plastic discs out of the motor arms.
      댓글 쓰기
    2. DROCON Ninja Camera Replacement: 6 단계, 이미지 2개 중 1개 DROCON Ninja Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Grasp the motor arm and pull up and away from the drone's body.
      • Repeat this step for the other front motor arm.
      댓글 쓰기
    3. DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 3개
      • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
      댓글 쓰기
    4. DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 3개
      • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
      • Gently pull the camera out from the control board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 27
전체 시간: 591
