주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7347 Battery Replacement
lee120496
lee1204965 다른 기여자
최종 수정일 February 16, 2025
10 분
쉬움
This guide would be useful for replacing faulty or broken battery for your Dell Inspiron 13-7347. Before you get started, please pay attention to few notes. 1)Make sure the battery that you are replacing is specifically for Dell Inspiron 13-7347. There are rumors that some of the batteries are universal as long as they are within the same company. It would be safe if you can find an exact matched battery from Dell Inspiron 13-7347 in order to prevent any troubles. 2) Be sure to use the tools we suggested, and be gentle when you are using the screwdriver. Its very easy to lead to stripped screws if you didn't use the screwdriver correctly or not gentle enough.
Make sure to follow the instructions step by step carefully.
필요한 것
도구
  1. Dell Inspiron 13-7347 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7347 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7347 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Battery Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 13-7347 Battery Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 13-7347 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Battery Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 13-7347 Battery Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 13-7347 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Battery Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7347 Battery Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7347 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
결론
작성자
5다른 기여자 명과 함께
lee120496
회원 가입일: 02/05/19
643 평판
안내서 4개를 작성함
UC Davis, Team S20-G8, Lore Winter 2019 UC Davis, Team S20-G8, Lore Winter 2019 회원
UCD-LORE-W19S20G8
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 22
전체 시간: 913
