주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7352 System Board Replacement
Chris Monte
Chris Monte7 다른 기여자
최종 수정일 August 1, 2024
10 분
조정
더 나은 이미지가 필요함
This guide will show users through the steps required to replace the main system board.
필요한 것
부품
도구
더보기...
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 System Board Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 System Board Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 13-7352 System Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): 4 단계, 이미지 3개 중 3개
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: 6 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 System Board Replacement, System Board: 6 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 System Board Replacement, System Board: 6 단계, 이미지 3개 중 3개
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: 9 단계, 이미지 3개 중 1개 Dell Inspiron 13-7352 System Board Replacement: 9 단계, 이미지 3개 중 2개 Dell Inspiron 13-7352 System Board Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron 13-7352 System Board Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Chris Monte
회원 가입일: 09/30/15
411 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 1,888
