주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7353 Screen Replacement
Stephany Marin Restrepo
Stephany Marin Restrepo4 다른 기여자
최종 수정일 April 11, 2023
10 분
조정
커뮤니티-기여 안내서
If you notice the screen of your Dell Inspiron 13-7353 laptop is damaged and needs to be replaced, this guide may help. This guide will show you how to replace the display screen in a few steps.
Before beginning the repair, turn off the laptop and unplug from the charging cord.
필요한 것
도구
  1. Dell Inspiron 13-7353 Screen Replacement, Flip the Computer: 1 단계, 이미지 1개 중 1개
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Screen Replacement, Secure the Base: 2 단계, 이미지 1개 중 1개
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Screen Replacement, Pry the Base cover: 3 단계, 이미지 1개 중 1개
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Screen Replacement, RAM: 4 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Screen Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Screen Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Screen Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Screen Replacement, Fan: 7 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement, Fan: 7 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement, Fan: 7 단계, 이미지 3개 중 3개
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Screen Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
  9. Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 9 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 9 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement, Heat Sink: 9 단계, 이미지 3개 중 3개
    • Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. Dell Inspiron 13-7353 Screen Replacement, Screen: 10 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement, Screen: 10 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement, Screen: 10 단계, 이미지 3개 중 3개
    • Remove the screws from the LCD cable bracket.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Screen Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Screen Replacement: 12 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 12 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Unscrew 2 M2.5 7mm screws, using the Phillips 1 screwdriver, on the right screen hinge.
    • Unscrew 1 M2.5 7mm screw, using the Phillips 1 screwdriver, on the left screen hinge.
  13. Dell Inspiron 13-7353 Screen Replacement: 13 단계, 이미지 2개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Carefully undo the tape
    • Unplug the two black and white wire leads
  14. Dell Inspiron 13-7353 Screen Replacement: 14 단계, 이미지 3개 중 1개 Dell Inspiron 13-7353 Screen Replacement: 14 단계, 이미지 3개 중 2개 Dell Inspiron 13-7353 Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Carefully remove the tape that is attached to the screen by prying it off with your fingers.
    • Remove the tape outlined in red.
    • Adjust the screen so that the laptop is open flat against the surface.
    • Remove the LCD display screen by pulling it gently away from the back.
결론
작성자
4다른 기여자 명과 함께
회원 가입일: 03/19/18
613 평판
안내서 5개를 작성함
댓글 2개
Wow. Thank you so much. I will do this when I get my replacement screen.
Chris Gallego - 답글
Finally tried this and noticed you left out the most difficult part which is the part of putting on the actually replacing the screen. This is only for removal of the screen. And the instructions are definitely not the same backwards. You left out the part with the cable/wires closing with the hinges being the most difficult part. I actually forced the cable too much stripped the cable that goes around the new screen. Have to order new cable now ugh
Chris Gallego -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 2,299
