주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7353 Speakers Replacement
Jack Wittman
Jack Wittman2 다른 기여자
최종 수정일 July 1, 2020
4 - 5 분
쉬움
If your Dell Inspiron 13-7353 is experiencing unclear, distorted, or low volume through the speakers, use this guide to replace the speakers.
Upon installation of a new set of speakers, ensure to test them by playing sound to ensure it is clear and not as quiet as it was before the replacement.
Be sure to turn off the computer and disconnect any external power before operating on any of the components of the device.
필요한 것
도구
더보기...
  1. Dell Inspiron 13-7353 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Speakers Replacement, Speakers: 4 단계, 이미지 1개 중 1개
    • Unplug the speaker wire from the motherboard.
  5. Dell Inspiron 13-7353 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the connecting wire from underneath the wire brackets from the back of the computer.
  6. Dell Inspiron 13-7353 Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Lift up both speakers away from the computer.
결론
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 18
전체 시간: 160
