주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7359 Battery Replacement
Valentin Medina
Valentin Medina2 다른 기여자
최종 수정일 April 20, 2018
2 - 5 분
쉬움
This guide will show you how to replace your device's battery without any hiccups. You will need one Phillips #0 screwdriver and one plastic spudger.
필요한 것
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 Battery Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 13-7359 Battery Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 13-7359 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Valentin Medina
회원 가입일: 01/30/18
703 평판
안내서 3개를 작성함
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G6
3 회원들
안내서 5개를 작성함
댓글 한 개
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 1,665
