주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7359 Cooling Fan Replacement
필요한 것
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 1/2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 2/2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: 4 단계, 이미지 1/1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Valentin Medina
회원 가입일: 01/30/18
697 평판
안내서 3개 작성하였습니다
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 19
전체 시간: 658
