Dell Inspiron 13-7359 Hard Drive Replacement
This guide will provide information needed to replace your Dell Inspiron 13-7359 hard drive. You will need a phillips #0 screwdriver and a small plastic spudger.
필요한 것
Flip your device over so the back cover is facing you.
Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
다른 6명이 해당 안내서를 완성하였습니다.
