주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7373 Motherboard Replacement
John Egan
John Egan4 다른 기여자
최종 수정일 April 28, 2021
15 - 25 분
조정
더 많은 이미지가 필요함
누락된 단계
If your laptop is not booting or functioning properly and all other potential hardware issues have been ruled out (Hard drive, RAM, etc.), then it might be time to replace your computer’s motherboard. The motherboard is the main circuit board of the computer that all other components connect to. This is a step-by-step guide to help replace your Dell Inspiron 13-7373 motherboard. Please note that this process does involve an almost complete disassembly of the computer! Take extra care when performing this repair and ensure that all components and screws/hardware are labeled and stored in a safe place.
필요한 것
도구
더보기...
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: 5 단계, 이미지 1개 중 1개
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: 7 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: 8 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 13-7373 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 13-7373 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Gently lift up on the motherboard to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
John Egan
회원 가입일: 10/25/19
485 평판
안내서 3개를 작성함
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G4
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 33
전체 시간: 1,431
