Dell Inspiron 14 3462 Memory Module Replacement
1 - 3 분
쉬움
커뮤니티-기여 안내서
In this guide, we will show you how to remove and replace the Memory Module.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
