주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3468 Hard-Drive Replacement
darrius
darrius2 다른 기여자
최종 수정일 November 2, 2019
10 - 25 분
쉬움
커뮤니티-기여 안내서
How to remove and replace the Hard-Drive.
필요한 것
도구
  1. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: 1 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Hard-Drive Cable: 2 단계, 이미지 1개 중 1개
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive  Bracket: 5 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Interposer: 6 단계, 이미지 1개 중 1개
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3468 Hard-Drive Replacement, Connecting the Interposer: 7 단계, 이미지 1개 중 1개
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screws: 8 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: 9 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screw Holes: 10 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: 11 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3468 Hard-Drive Replacement, Sliding the Hard-Drive Cable: 12 단계, 이미지 1개 중 1개
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 168
