주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3541 Battery Replacement
Allison
Allison2 다른 기여자
최종 수정일 May 17, 2016
5 초 - 5 분
매우 쉬움
Before starting this guide, make sure your laptop is powered completely off and detached from the power cable. This replacement will be helpful to learn for replacing most other components of the laptop, as well as, replacing the battery itself.
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Allison
회원 가입일: 03/04/16
571 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개를 작성함
댓글 2개
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - 답글
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 1,871
