주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3541 Keyboard Replacement
Allison
Allison3 다른 기여자
최종 수정일 May 17, 2016
10 - 20 분
조정
By reading this guide, you will learn how to remove the laptop keyboard so that it can be replaced with another. Make sure the laptop is completely powered off and disconnected from the power source before starting this guide.
필요한 것
도구
  • Spudger
    Spudger
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Allison
회원 가입일: 03/04/16
571 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 30
전체 시간: 3,530
