주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3565 Battery Replacement
Terrence15
Terrence152 다른 기여자
최종 수정일 February 4, 2025
15 - 40 초
매우 쉬움
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Battery.
필요한 것
부품
  1. Dell Inspiron 15 3565 Battery Replacement, Sliding the Battery Latch: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps inBefore Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Slide the battery-release latch to the unlocked position.
    • You hear a click sound when the battery is unlocked.
  2. Dell Inspiron 15 3565 Battery Replacement, Turn the Computer Over: 2 단계, 이미지 1개 중 1개
    • Using your fingertips, lift the battery at an angle and remove it from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  3. Dell Inspiron 15 3565 Battery Replacement, Installing the Battery: 5 단계, 이미지 1개 중 1개
    • Place the battery in the battery bay and snap the battery into place.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 610
