Dell Inspiron 15 5578 2-in-1 Memory Module Replacement
2 - 5 분
매우 쉬움
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Memory Module.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
거의 끝나갑니다!
결승점
