주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5584 Hard Drive Replacement
Sam Vorn
Sam Vorn4 다른 기여자
최종 수정일 May 7, 2024
7 - 9 분
조정
일관성 없는 이미지
Use this guide to replace the hard drive in your Dell Inspiron 15 5584.
The hard drive is a component that gathers and contains data within your device. A faulty drive can slow operation and cause application crashes as well as the loss of files.
If you are sure the issue is your hard drive, make sure to save your files to an external storage device before any tampering in order to save data that could be lost otherwise. Be sure to drain the battery and shut down the device as removing the battery is necessary to remove the hard drive. A live battery serves as a fire hazard and can cause personal injury or component damage.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. Dell Inspiron 15 5584 Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift up the motherboard ribbon latch using a pair of tweezers.
    • Gently lift the ribbon cable from the motherboard connector socket.
    • Pulling out the ribbon cable too quickly can damage the connector.
  8. Dell Inspiron 15 5584 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3 mm hard drive cover screws using a JIS #0 screwdriver.
  9. Dell Inspiron 15 5584 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the hard drive cover plate from the device.
    • Unplug the connector cable from the hard drive.
    • Remove the hard drive from the device and place it safely to the side.
결론
작성자
4다른 기여자 명과 함께
Sam Vorn
회원 가입일: 03/29/22
977 평판
안내서 9개를 작성함
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 13
전체 시간: 533
