주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7590 2-in-1 Keys Replacement
Ojonukpemi F Ameh
Ojonukpemi F Ameh2 다른 기여자
최종 수정일 March 28, 2024
5 분
쉬움
잘못된 도구
A spoiled laptop key can be very annoying to work with. Trying to use your laptop with a stuck key, or an empty space where a key should be, gets old very fast.
This guide goes over replacing Dell’s Inspiron 15 7590 2-in-1 laptop keys, which are a little tricky due to Dell’s usage of more than one keyboard manufacturer for the exact same model.
A quick tip is to take a look under the key to be replaced and reference that with the key types on any old site for replacements. The key types for the 7590 I’ve encountered are D36, D44, and D81 but make sure your keyboard matches your replacement.
This guide then comes in as a great next step and will help in removing and replacing your bad keys.
필요한 것
부품
도구
  • Spudger
    Spudger
더보기...
  1. Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 7590 2-in-1 Keys Replacement, Keys: 1 단계, 이미지 2개 중 2개
    • Position a spudger between the key cap and its hinge.
    • Push up with steady force to snap the key cap away from the hinge.
    • Use a spudger to pry under the corners of the hinge to remove it.
    • Remember the orientation of your key hinge and which holes go to the upper metal holders.
  2. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 2 단계, 이미지 2개 중 2개
    • Align the new hinge with the metal holders on the keyboard.
    • Push the hinge into place and lock it onto the metal holders.
    • Make sure the hinge lies flat on the metal holders. If it doesn't, check the orientation of the hinge.
  3. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the key cap over and determine the positions of the spikes jutting out.
    • Align the spikes with the holes on the hinge and press the key cap onto the hinge.
  4. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 4 단계, 이미지 1개 중 1개
    • Press down on the key to snap it into place.
  5. Dell Inspiron 15 7590 2-in-1 Keys Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15 7590 2-in-1 Keys Replacement: 5 단계, 이미지 3개 중 3개
    • To replace big keys, examine the other side of the key cap and locate the metal wires attached to the holders on the back of the key.
    • Examine the space the key will enter, and locate the metal holders with holes in them.
    • Position the key so all the metal ends can enter a hole and insert the metal ends into the holes.
    • Push down on the key and adjust the keycap to make sure its metal attachments slide into their holders.
결론
If you encountered unsolvable difficulties replacing a key, make sure it’s aligned properly and crosscheck that the key is the same model as your laptop.
작성자
2다른 기여자 명과 함께
Ojonukpemi F Ameh
회원 가입일: 03/22/21
121 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 30
지난 30일: 86
전체 시간: 3,291
