주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Display Assembly Replacement
Terrence15
Terrence15다른 한 명의 기여자
최종 수정일 November 22, 2019
9 - 20 분
조정
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
도구
  1. Dell Inspiron 15 Display Assembly Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer. After working inside your computer, follow the instructions in After working inside your computer.
    • Remove the screws that secure the display hinges to the palm-rest assembly and open the hinges to an angle of 90 degrees.
  2. Dell Inspiron 15 Display Assembly Replacement, Note the Antenna Cable: 2 단계, 이미지 1개 중 1개
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  3. Dell Inspiron 15 Display Assembly Replacement, Noting the Display Cable: 3 단계, 이미지 1개 중 1개
    • Note the display cable routing and remove the cable from its routing guides on the palm-rest assembly.
  4. Dell Inspiron 15 Display Assembly Replacement, Open the Assembly: 4 단계, 이미지 1개 중 1개
    • Open the palm-rest assembly.
  5. Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15 Display Assembly Replacement, Lifting the Palm-Rest Assembly: 5 단계, 이미지 2개 중 2개
    • Lift the palm-rest assembly at an angle off the display assembly.
  6. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: 6 단계, 이미지 1개 중 1개
    • Place the display assembly on a clean, flat surface.
  7. Dell Inspiron 15 Display Assembly Replacement, Placing the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Place the NEW display assembly on the palm-rest assembly.
  8. Dell Inspiron 15 Display Assembly Replacement, Close the Display Hinges: 8 단계, 이미지 1개 중 1개
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  9. Dell Inspiron 15 Display Assembly Replacement, Replace the Screws: 9 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  10. Dell Inspiron 15 Display Assembly Replacement, Route the Display Cable: 10 단계, 이미지 1개 중 1개
    • Route the display cable through its routing guides on the palm-rest assembly.
  11. Dell Inspiron 15 Display Assembly Replacement, Routing the Antenna Cables: 11 단계, 이미지 1개 중 1개
    • Route the antenna cables through its routing guides on the palm-rest assembly.
    • Close the display and turn the computer over.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 한 개
I can't replace the cables on the left side of the lid through the hinge.
Peter Meyer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 53
전체 시간: 2,292
