주요 콘텐츠로 건너뛰기
Dell Inspiron 15 M5030 Display Assembly Replacement
Terrence15
Terrence15다른 한 명의 기여자
최종 수정일 November 22, 2019
9 - 15 분
조정
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
도구
  1. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the base of the computer.
  2. Dell Inspiron 15 M5030 Display Assembly Replacement, Open the Display: 2 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnecting the Antenna Cable: 3 단계, 이미지 1개 중 1개
    • Make a note of the Wireless Mini-Card antenna cable routing and disconnect the Wireless Mini-Card antenna cable from the Wireless Mini- Card.
  4. Dell Inspiron 15 M5030 Display Assembly Replacement, Disconnect the Display Cable: 4 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  5. Dell Inspiron 15 M5030 Display Assembly Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 15 M5030 Display Assembly Replacement, Removing the Display Assembly: 6 단계, 이미지 1개 중 1개
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron 15 M5030 Display Assembly Replacement, Placing the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Display Cable: 8 단계, 이미지 1개 중 1개
    • Route the display cable into the routing guide and connect the display cable to the connector on the system board.
  9. Dell Inspiron 15 M5030 Display Assembly Replacement, Routing the Cable: 9 단계, 이미지 1개 중 1개
    • Route the Mini-Card antenna cable into the routing guide and connect the Mini-Card antenna cable to the connector on the Mini-Card.
  10. Dell Inspiron 15 M5030 Display Assembly Replacement, Replace the Screws: 10 단계, 이미지 1개 중 1개
    • Turn the computer over and replace the two screws at the base of the computer.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 122
