주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5548 Keyboard Replacement
Hunter Oliver
Hunter Oliver7 다른 기여자
최종 수정일 June 29, 2023
10 - 20 분
조정
액션 샷
더 나은 이미지가 필요함
This repair guide will show you how to replace the keyboard on your Dell Inspiron 15-5548 laptop. The keyboard is a critical part of your laptop, and whether you have broken keys or if the whole keyboard is nonfunctional, this repair guide will show you how to replace the keyboard with a new one.
However, if the problem is stuck keys, you should first attempt to make them unstuck. This can be accomplished by sliding a thin object, like a flat head screwdriver, under the groove to push the built up dust away and restore the key's functionality. Additionally, a dust blower may remove the buildup.
If after trying these steps, the keyboard still isn't working, then you should proceed with the repair. This repair guide is intended for people who are comfortable working with simple tools and who have some basic knowledge of electronics. Once you have powered off the device and unplugged the laptop from the charger, you can begin the repair.
필요한 것
부품
도구
더보기...
  1. Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Open up the front of the laptop.
    • Locate the 5 holes at the top of the keyboard, as circled in Picture 2.
    • Use the metal spudger to pry up the keyboard at each of the 5 points.
    • This may take some extra force, and it should pop when it is pried off.
  2. Dell Inspiron 15-5548 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15-5548 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15-5548 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • When all the points have been pried up, gently lift the keyboard.
    • Lift the ZIF tabs holding down the two ribbon cables, and gently remove them.
    • Remove the keyboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Hunter Oliver
회원 가입일: 09/20/17
288 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 1,718
