주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5558 Memory Modules Replacement
Terrence15
Terrence152 다른 기여자
최종 수정일 November 23, 2019
2 - 4 분
매우 쉬움
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Memory Modules.
  1. Dell Inspiron 15-5558 Memory Modules Replacement, Popping up the Memory Module: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15-5558 Memory Modules Replacement, Remove the Memory Module: 2 단계, 이미지 1개 중 1개
    • Remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  3. Dell Inspiron 15-5558 Memory Modules Replacement, Remove the Memory Module: 4 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 568
