주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5558 Screen Replacement
Adam Lourenco
Adam Lourenco3 다른 기여자
최종 수정일 December 21, 2017
15 분
조정
If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Screen Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15-5558 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-5558 Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
  5. Dell Inspiron 15-5558 Screen Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15-5558 Screen Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15-5558 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 15-5558 Screen Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 15-5558 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam Lourenco
회원 가입일: 10/19/17
793 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G4
3 회원들
안내서 5개를 작성함
댓글 3개
Where can I buy the screen from?
wardak_90 - 답글
How many pins is the screen connector? 30? 40?
Adrian Lewis - 답글
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
James Diamond - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 27
전체 시간: 4,832
