주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5565 Coin Cell Battery Replacement
Avery Wasylyszyn
Avery Wasylyszyn3 다른 기여자
최종 수정일 May 31, 2023
1 분
매우 쉬움
This guide will show you how to replace the coin-cell battery or CMOS battery (complementary metal oxide semiconductor) in a Dell Inspiron 15-5565 laptop. The battery is a CR-2032.
Some common issues to identify a faulty coin-cell battery are as follows: if the date and time settings are incorrect, slowed, or stopped; you are prompted to reset the date and time when you power on the computer, or if you lose your BIOS setting once the computer powers off. Please see this page for troubleshooting steps.
You can order a new battery here or here.
필요한 것
도구
  1. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Coin Cell Battery Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15-5565 Coin Cell Battery Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15-5565 Coin Cell Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Coin Cell Battery Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-5565 Coin Cell Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15-5565 Coin Cell Battery Replacement, Coin Cell Battery: 5 단계, 이미지 3개 중 3개
    • Remove the coin-cell battery by carefully pulling the plug from the slot.
    • The coin-cell battery is simply plugged into the circuitry. No screws or tools are needed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Avery Wasylyszyn
회원 가입일: 03/08/23
228 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 32
전체 시간: 485
