주요 콘텐츠로 건너뛰기
Dell Inspiron 1525 Wireless Mini-Card Replacement
Miroslav Djuric
Miroslav Djuric2 다른 기여자
최종 수정일 November 13, 2015
10 - 15 분
쉬움
Use this guide to help you replace the Wireless Mini-Card in a Dell Inspiron 1525.
필요한 것
도구
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Wireless Mini-Card Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: 3 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: 3 단계, 이미지 2개 중 2개
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: 4 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Wireless Mini-Card Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Miroslav Djuric
159,456 평판
안내서 144개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 32
전체 시간: 8,994
