Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
9 - 15 분
쉬움
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
필요한 것
Remove the screws that secure the hard-drive assembly to the computer base.
Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
Replace the screws that secure the hard-drive assembly to the computer base.
거의 끝나갑니다!
결승점
