주요 콘텐츠로 건너뛰기
Dell Inspiron 15R 5537 Palm Rest Replacement
Ashton Floda
Ashton Floda3 다른 기여자
최종 수정일 December 12, 2019
15 - 25 분
조정
커뮤니티-기여 안내서
If the palm rest is cracked and broken or the touchpad is malfunctioning on your Dell Inspiron 15R 5537, this will guide will show you how to properly remove the palm rest so you can replace it with a new one.
The palm rest, connected by two ribbon cables, is the inside cover of the computer that contains the touchpad. A cracked palm rest can cause exposure to the interior hardware of the laptop, and faulty ribbon cables can lead to a malfunctioning touchpad.
It is important to make sure that the touchpad is properly cleaned and the ribbon cables are fully connected before deciding to take apart your laptop.
Before beginning this guide, make sure your laptop is powered off and disconnected from any external power source.
필요한 것
도구
더보기...
  1. Dell Inspiron 15R 5537 Palm Rest Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Palm Rest Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement: 2 단계, 이미지 3개 중 3개
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Palm Rest Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement: 4 단계, 이미지 3개 중 3개
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 Palm Rest Replacement, Wi-Fi Module: 5 단계, 이미지 1개 중 1개
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 Palm Rest Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 6 단계, 이미지 2개 중 2개
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 Palm Rest Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Dell Inspiron 15R 5537 Palm Rest Replacement, Remove the Screws: 9 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the computer base.
  9. Dell Inspiron 15R 5537 Palm Rest Replacement, Sliding the Hard Drive Assembly: 10 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  10. Dell Inspiron 15R 5537 Palm Rest Replacement, Lifting the Hard Drive Assembly: 11 단계, 이미지 1개 중 1개
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  11. Dell Inspiron 15R 5537 Palm Rest Replacement, Remove the Screws: 12 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Dell Inspiron 15R 5537 Palm Rest Replacement, Lifting the Hard-Drive Bracket: 13 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket off the hard drive.
  13. Dell Inspiron 15R 5537 Palm Rest Replacement, Align the Screw Holes: 14 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  14. Dell Inspiron 15R 5537 Palm Rest Replacement, Replace the Screws: 15 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Inspiron 15R 5537 Palm Rest Replacement, Placing the Hard Drive Assembly: 16 단계, 이미지 1개 중 1개
    • Slide and place the hard-drive assembly in the hard-drive bay.
  16. Dell Inspiron 15R 5537 Palm Rest Replacement, Sliding the Hard-Drive Assembly: 17 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  17. Dell Inspiron 15R 5537 Palm Rest Replacement, Replace the Screws: 18 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the computer base.
  18. Dell Inspiron 15R 5537 Palm Rest Replacement, Palm Rest: 19 단계, 이미지 1개 중 1개
    • Remove thirteen 5mm Phillips #000 screws from the back cover of the laptop.
  19. Dell Inspiron 15R 5537 Palm Rest Replacement: 20 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 20 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement: 20 단계, 이미지 3개 중 3개
    • Use the opening tool to unplug the palm rest cables and slide the cables out.
  20. Dell Inspiron 15R 5537 Palm Rest Replacement: 21 단계, 이미지 1개 중 1개
    • Remove seven 5mm Phillips #000 screws from the midframe.
  21. Dell Inspiron 15R 5537 Palm Rest Replacement: 22 단계, 이미지 3개 중 1개 Dell Inspiron 15R 5537 Palm Rest Replacement: 22 단계, 이미지 3개 중 2개 Dell Inspiron 15R 5537 Palm Rest Replacement: 22 단계, 이미지 3개 중 3개
    • Use the opening tool to lift the edges of the palm rest. Once all of the sides are lifted, pull the palm rest off.
결론
작성자
3다른 기여자 명과 함께
Ashton Floda
회원 가입일: 09/16/19
572 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 25
전체 시간: 532
