Dell Inspiron 3542 Hard Drive Replacement
This guide provides steps on how to remove and replace the hard drive for the Dell Inpiron 3542. This will allow you to carefully remove and replace your hard drive if broken, or if you want to upgrade the hard drive.
The hard drive is the device in your computer that stores and retrieves the data that you have saved. If you are running low on space, upgrading your hard drive would allow you to have more space and continue to work. If your hard drive fails, replacing your hard drive will allow you to continue using your computer.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
Flip computer over to the bottom and slide the latches on both sides of battery outwards.
Remove the battery from computer.
다른 한 분이 해당 안내서를 완성하였습니다.
