주요 콘텐츠로 건너뛰기
Dell Inspiron 3552 Hard Drive Replacement part 2
Jordon Dozier
Jordon Dozier2 다른 기여자
최종 수정일 August 2, 2024
예상시간 없음
조정
문법 검토
더 많은 이미지가 필요함
커뮤니티-기여 안내서
  1. Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: 1 단계, 이미지 3개 중 1개 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: 1 단계, 이미지 3개 중 2개 Dell Inspiron 3552 Hard Drive Replacement part 2, Removing hard drive: 1 단계, 이미지 3개 중 3개
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly
    • Open the latch and disconnect the hard-drive cable from the system board
    • Lift the hard-drive assembly off the palm-rest assembly
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift it off the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive
    • Connect the interposer to the hard-drive assembly
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly
    • Replace the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Slide the hard-drive cable into the system-board connector and close the latch to secure the cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordon Dozier
회원 가입일: 02/10/21
1,663 평판
안내서 12개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 371
