주요 콘텐츠로 건너뛰기
Dell Inspiron 530 Replacement of GPU
bacon
bacon3 다른 기여자
최종 수정일 August 9, 2019
5 - 10 분
쉬움
커뮤니티-기여 안내서
You will need a good knowledge of computers to know how to do this.
필요한 것
부품
도구
더보기...
  1. Dell Inspiron 530 Replacement of GPU, GPU: 1 단계, 이미지 1개 중 1개
    • Remove the side panel, and and and screws that may be holding it in place.
  2. Dell Inspiron 530 Replacement of GPU: 2 단계, 이미지 1개 중 1개
    • Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Take the old GPU out and put the new GPU in its place.
    • Make sure that you have correctly grounded yourself and that you are using proper tools to reduce the risk of ESD and component destruction. Also make sure that the graphics card that you are using has enough voltage to be powered by your current power supply.
결론
To reassemble your device, reattach any cables and screws that were disconnected and put the cover back on.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
bacon
회원 가입일: 04/26/16
277 평판
안내서 1개를 작성함
댓글 한 개
En français on ne dit pas “Processeur graphique” mais “Carte Graphique” car on achète et on change toute la carte graphique.
Hyperion - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 46
전체 시간: 2,077
