Dell Inspiron 8600 Lower Case Replacement
This guide will show you how to remove the lower case of a Dell Inspiron 8600 for replacement or repair. In this guide we’ll show you how to remove critical components, how to correctly reassemble the device.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
Remove the two screws holding down the upper case with a Phillips #1 screwdriver.
