주요 콘텐츠로 건너뛰기
Dell Inspiron 8600 Top Case Replacement
Perry
Perry7 다른 기여자
최종 수정일 March 3, 2016
15 - 30 분
조정
액션 샷
더 많은 이미지가 필요함
잘못된 도구
누락된 단계
Follow this guide to replace the top case of the Dell Inspiron 8600.
필요한 것
도구
  1. Dell Inspiron 8600 Top Case Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Top Case Replacement, Power Button: 2 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Top Case Replacement, Power Button: 2 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Top Case Replacement, Power Button: 2 단계, 이미지 3개 중 3개
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Top Case Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Dell Inspiron 8600 Top Case Replacement, Display Module: 4 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Top Case Replacement, Display Module: 4 단계, 이미지 2개 중 2개
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Top Case Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Top Case Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Top Case Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Top Case Replacement: 7 단계, 이미지 1개 중 1개
    • Now remove the display module.
  8. Dell Inspiron 8600 Top Case Replacement, Top Case: 8 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Top Case Replacement, Top Case: 8 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Top Case Replacement, Top Case: 8 단계, 이미지 3개 중 3개
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  9. Dell Inspiron 8600 Top Case Replacement: 9 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Top Case Replacement: 9 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Top Case Replacement: 9 단계, 이미지 3개 중 3개
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  10. Dell Inspiron 8600 Top Case Replacement: 10 단계, 이미지 1개 중 1개
    • LCD should remove smoothly.
    • The top case will be what remains.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Perry
회원 가입일: 04/12/11
251 평판
안내서 4개를 작성함
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 2,221
