주요 콘텐츠로 건너뛰기
Dell Inspiron 910 Speaker Replacement
Kyle Beekman
Kyle Beekman11 다른 기여자
최종 수정일 January 2, 2024
15 분
조정
액션 샷
더 나은 이미지가 필요함
If your Dell Inspiron 910 is struggling with audio issues or becomes silent, looking into a speaker replacement might be the solution. This repair targets sound-related problems, reviving your laptop's auditory experience.
필요한 것
도구
더보기...
  1. Dell Inspiron 910 Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Speaker Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • After removing the keyboard, use the plastic opening tool or other form of leverage to remove the rest of the silver casing.
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
  5. Dell Inspiron 910 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic tool to carefully pry the silver portion front of the top away from the colored portion.
  6. Dell Inspiron 910 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two small screws at the bottom corners of the speaker assembly.
    • Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
  7. Dell Inspiron 910 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Slide out the cables connected to the speakers and the base below the keyboard.
    • Remove the speakers from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Kyle Beekman
회원 가입일: 04/05/12
144 평판
안내서 6개를 작성함
Cal Poly, Team 14-10, Forte Spring 2012 Cal Poly, Team 14-10, Forte Spring 2012 회원
CPSU-FORTE-S12S14G10
5 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 19
전체 시간: 1,606
