Dell Latitude E7440 Battery Replacement
You may have noticed that your device no longer powers on or no longer functions without being plugged in. Laptop batteries naturally degrade with use, losing the ability to hold a full charge. Luckily, Dell designed the Latitude E7440’s battery to be easily replaceable.
Power off your laptop before starting.
Flip the device over so that the vents on the bottom are facing away from you.
Place your finger on the latch located in the center of the laptop.
Slide the latch to the right, applying enough force to reveal a red indicator.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 2개
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Any recommended site to buy original battery?
