주요 콘텐츠로 건너뛰기
Dell Latitude E7440 RAM Replacement
Akash Kedia
Akash Kedia다른 한 명의 기여자
최종 수정일 March 6, 2019
5 분
쉬움
You may have noticed your computer slowing down when using several programs. This is likely a result of insufficient RAM. Fortunately, Dell made RAM replacement straightforward, allowing you to easily upgrade your RAM capacity.
필요한 것
도구
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: 1 단계, 이미지 1개 중 1개
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 3개 중 1개 Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 3개 중 2개 Dell Latitude E7440 RAM Replacement, Release the battery: 2 단계, 이미지 3개 중 3개
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: 3 단계, 이미지 1개 중 1개
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: 4 단계, 이미지 2개 중 1개 Dell Latitude E7440 RAM Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude E7440 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 3개 중 1개 Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 3개 중 2개 Dell Latitude E7440 RAM Replacement: 6 단계, 이미지 3개 중 3개
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Akash Kedia
회원 가입일: 01/24/19
1,445 평판
안내서 5개를 작성함
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 회원
CPSU-WHITE-W19S2G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 56
전체 시간: 2,905
