주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Streak 7 Battery Replacement
필요한 것
  1. Dell Streak 7 Battery Replacement, Front Panel Assembly: 1 단계, 이미지 1개 중 1개
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
    댓글 쓰기
  2. Dell Streak 7 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the button cover by lifting the cover away from the tablet.
    댓글 쓰기
  3. Dell Streak 7 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Torx screwdriver, remove the 4mm screws.
    댓글 쓰기
  4. Dell Streak 7 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • With the Torx screwdriver, remove the two 5mm screws.
    댓글 쓰기
  5. Dell Streak 7 Battery Replacement: 5 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
    댓글 쓰기
  6. Dell Streak 7 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
    댓글 쓰기
  7. Dell Streak 7 Battery Replacement: 7 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
    댓글 쓰기
  8. Dell Streak 7 Battery Replacement, Headphone Jack: 8 단계, 이미지 1개 중 1개
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
    댓글 쓰기
  9. Dell Streak 7 Battery Replacement: 9 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the headphone jack up, away from the case.
    댓글 쓰기
  10. Dell Streak 7 Battery Replacement, GSM Module: 10 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement, GSM Module: 10 단계, 이미지 2개 중 2개
    • With the spudger, disconnect the antenna cable located on the module.
    댓글 쓰기
  11. Dell Streak 7 Battery Replacement: 11 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the tape connected to the GSM module.
    댓글 쓰기
  12. Dell Streak 7 Battery Replacement: 12 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
    댓글 쓰기
  13. Dell Streak 7 Battery Replacement: 13 단계, 이미지 1개 중 1개
    • Disconnect the GSM module by lifting the module up, out of the case.
    댓글 쓰기
  14. Dell Streak 7 Battery Replacement, Motherboard: 14 단계, 이미지 3개 중 1개 Dell Streak 7 Battery Replacement, Motherboard: 14 단계, 이미지 3개 중 2개 Dell Streak 7 Battery Replacement, Motherboard: 14 단계, 이미지 3개 중 3개
    • Using the spudger, disconnect the front camera by lifting up on the connector.
    댓글 쓰기
  15. Dell Streak 7 Battery Replacement: 15 단계, 이미지 1개 중 1개
    • Using the Torx screwdriver, remove the six 3mm screws .
    댓글 쓰기
  16. Dell Streak 7 Battery Replacement: 16 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement: 16 단계, 이미지 2개 중 2개
    • Lift up the metal cover.
    댓글 쓰기
  17. Dell Streak 7 Battery Replacement: 17 단계, 이미지 1개 중 1개
    • Use the spudger to lift the vibration motor out of the case.
    댓글 쓰기
  18. Dell Streak 7 Battery Replacement: 18 단계, 이미지 1개 중 1개
    • Pull out the motherboard and the battery.
    댓글 쓰기
  19. Dell Streak 7 Battery Replacement, Battery: 19 단계, 이미지 2개 중 1개 Dell Streak 7 Battery Replacement, Battery: 19 단계, 이미지 2개 중 2개
    • Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jair Garcia Varela
회원 가입일: 09/29/16
337 평판
안내서 2개를 작성함
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 1,512
