Dell Vostro 15 3562 Memory Module Replacement
Slide the release latch to release the battery [1].
Remove the battery from the computer [2].
Remove the M2L3 screw that secures the optical drive to the computer [1].
Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
Slide the optical drive out of the computer [3].
Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
Disconnect the optical drive connector and lift it to remove it from the system board [1].
Remove the M2L5 screws that secure the base cover [2].
Pull the clips securing the memory module until the memory module pops up [1].
Remove the memory module from the system board [2].
