주요 콘텐츠로 건너뛰기
Dell Vostro 3360 Palm-Rest Replacement
Johnathan Hammond
Johnathan Hammond2 다른 기여자
최종 수정일 November 5, 2019
15 - 30 분
조정
커뮤니티-기여 안내서
In this guide, we will be showing you how to remove and replace the Palm-Rest.
필요한 것
도구
  1. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: 1 단계, 이미지 1개 중 1개
    • Remove the screw that secures the access panel to the computer.
  2. Dell Vostro 3360 Palm-Rest Replacement, Remove the Access Panel: 2 단계, 이미지 1개 중 1개
    • Remove the access panel from the computer.
  3. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: 3 단계, 이미지 1개 중 1개
    • Remove the screw that secures the keyboard to the chassis.
  4. Dell Vostro 3360 Palm-Rest Replacement, Prying the Keyboard: 4 단계, 이미지 1개 중 1개
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Dell Vostro 3360 Palm-Rest Replacement, Flipping the Keyboard: 5 단계, 이미지 1개 중 1개
    • Flip the keyboard over and lay it on the palmrest.
  6. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Clip: 6 단계, 이미지 1개 중 1개
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  7. Dell Vostro 3360 Palm-Rest Replacement, Display-Hinge Cover: 7 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Palm-Rest Replacement, Remove the Display Hinge Cover: 8 단계, 이미지 1개 중 1개
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Palm-Rest Replacement, Prying the Rubber Pads: 9 단계, 이미지 1개 중 1개
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: 10 단계, 이미지 1개 중 1개
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the Board Cable: 11 단계, 이미지 1개 중 1개
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the LED Cable: 12 단계, 이미지 1개 중 1개
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: 13 단계, 이미지 1개 중 1개
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Palm-Rest Replacement, Prying the Edges of the Palm-Rest: 14 단계, 이미지 1개 중 1개
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Palm Rest: 15 단계, 이미지 1개 중 1개
    • Lift the palm-rest up and away from the computer.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,237 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 233
