주요 콘텐츠로 건너뛰기
Dell Vostro 3500 WiFi Card Replacement
Philip Le Riche
Philip Le Riche다른 한 명의 기여자
최종 수정일 February 8, 2023
10 - 20 분
쉬움
커뮤니티-기여 안내서
If your laptop won’t connect reliably to your WiFi router despite a good signal, it may be beause of an incompatibility between your router and the WiFi card in your laptop. An easy solution is to replace the WiFi card in your laptop with one of a different make or model. They are a standard item, and if you find one the same size and with the same kind of connectors and screw holes then it’s almost certain that it’ll work and Windows will recognise it.
필요한 것
도구
  1. Dell Vostro 3500 WiFi Card Replacement, Sliding the Battery Latch: 1 단계, 이미지 1개 중 1개
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3500 WiFi Card Replacement, Sliding the Battery Release Latch: 2 단계, 이미지 1개 중 1개
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3500 WiFi Card Replacement, Removing the Battery: 3 단계, 이미지 1개 중 1개
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3500 WiFi Card Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over and remove two screws securing the service cover.
  5. Dell Vostro 3500 WiFi Card Replacement, Removing the Base Cover: 5 단계, 이미지 1개 중 1개
    • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
    • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
  6. Dell Vostro 3500 WiFi Card Replacement, WiFi card removal: 6 단계, 이미지 1개 중 1개
    • Gently snap off the two aerial connectors from the WiFi card.
    • On reassembly they simply snap back on with firm pressure, but first make sure they are positioned correctly over their sockets.
    • Remove a single screw adjacent to one of the aerial sockets retaining the wWiFi card, then lift it out.
    • On resassembly, ensure that the WiFi card is fully inserted into its sovket before angling it down and reinserting the screw.
결론
작성자
1다른 기여자 명과 함께
Philip Le Riche
회원 가입일: 02/18/14
30,768 평판
안내서 47개를 작성함
Restart Project Restart Project 회원
Local Repair Groups
23 회원들
안내서 661개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 1,137
