주요 콘텐츠로 건너뛰기
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Dylan J. Souza
Dylan J. Souza2 다른 기여자
최종 수정일 July 14, 2019
7 분
쉬움
This guide will guide the user through all of the necessary steps to replace the disk drive tray latch on their Dell Vostro 3550. This component may need to be replaced if the user notices that the tray will not eject or close properly. The cause of this problem is that the latch mechanism is broken inside the disk tray. This is a common problem that occurs when users close their disk drive with a lot of force.
필요한 것
도구
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 1 단계, 이미지 3개 중 1개 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 1 단계, 이미지 3개 중 2개 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 1 단계, 이미지 3개 중 3개
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 2 단계, 이미지 3개 중 1개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 2 단계, 이미지 3개 중 2개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 3 단계, 이미지 3개 중 1개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 3 단계, 이미지 3개 중 2개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 4 단계, 이미지 3개 중 1개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 4 단계, 이미지 3개 중 2개 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
결론
작성자
2다른 기여자 명과 함께
Dylan J. Souza
회원 가입일: 03/22/19
781 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 UMass Dartmouth, Team S8-G6, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G6
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 10
전체 시간: 280
