주요 콘텐츠로 건너뛰기
Dell Vostro 3550 Display Assembly Replacement
Dylan J. Souza
Dylan J. Souza2 다른 기여자
최종 수정일 July 14, 2019
30 분
조정
This guide will demonstrate how to replace the display assembly on the Dell Vostro 3550. This replacement may be needed if the screen is cracked or damaged. When performing the steps in this guide, be sure to exercise caution with all steps involving wires or cables.
필요한 것
도구
  1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 1개 Dell Vostro 3550 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 2개
    • Grip the back trim of the laptop and pull upwards to remove it.
  2. Dell Vostro 3550 Display Assembly Replacement: 2 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 2 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the plastic opening tool around the perimeter of the display bezel.
    • Carefully remove the bezel from the display.
  3. Dell Vostro 3550 Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
    • When all six screws are removed, gently lower the display to reveal the camera cable.
  4. Dell Vostro 3550 Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the camera ribbon cable by gently pulling it away from its connector.
  5. Dell Vostro 3550 Display Assembly Replacement: 5 단계, 이미지 2개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
  6. Dell Vostro 3550 Display Assembly Replacement: 6 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 6 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Gently lower the display into a resting position.
  7. Dell Vostro 3550 Display Assembly Replacement: 7 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 7 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Loosen the clear tape fastening the ribbon cable to the display.
    • Carefully pull the ribbon cable away from the connector.
  8. Dell Vostro 3550 Display Assembly Replacement: 8 단계, 이미지 3개 중 1개 Dell Vostro 3550 Display Assembly Replacement: 8 단계, 이미지 3개 중 2개 Dell Vostro 3550 Display Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Peel the ribbon cable away from the display.
    • Remove the display from the laptop.
결론
작성자
2다른 기여자 명과 함께
Dylan J. Souza
회원 가입일: 03/22/19
781 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 UMass Dartmouth, Team S8-G6, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G6
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 846
